Water Pump fan assembly 1999 Tahoe 5.7 v8
I did the same thing. I got frustrated and pulled the old water pump off with the fan, clutch, and pulley still attached. I ended up buying a new fan, clutch, and pulley for the new water pump because I broke two of the fan blades fooling with it and the total price for all three parts was just over $100. The parts store told me there was a special tool to remove the fan, but they could not find it in their catalog (Napa Auto Parts, Memphis, TN).
I also need to repair the lower intake manifold gasket, but I started with the water pump and radiator hoses to elliminate sources of leaks. My Tahoe started leaking/using coolant a year ago at a rate of about a gallon every three weeks until this week it was up to 1 gallon a day, so I thought I had better do something about it. The local shop wanted $650 just to repair the intake manifold gasket and the water pump was extra on top of that. I figure I could save some money by doing the water pump myself, but I had not anticipated the trouble I had with the fan assembly.
I am not confident I can do the intake manifold gasket because of all of the linkages, wires, gas lines, etc. that have to be removed from the top of the manifold. I looked at the throttle lnkage and could not figure out how to disconnect the cables from the throttle body without breaking them. I guess I need a shop manual. Helm wants $300 for the DVD new, but I saw a DVD shop manual on eBay for $50, I just don't know if I can trust someone on eBay not to rip me off. I also saw the set of paper shop manual for $50 on eBay. Is the DVD better? It appears to have been revised since the paper manuals were printed.
