removing interior parts to access wires
cardmaster91
hi, im trying to run all of my door speakers on the front connection. How exactly would you remove the interior siding i guess, i really have no idea what it is called, to access the wires that go into the doors?
oh, i have one more question, i probably should have put this in the audio section but since i am already posting here.
Im not sure if all tahoe's come stock with an amp, but i don't think mine has one. There is no fuse in the power amp circuit. but anyways, i was wondering if the stock radio or amp if a actually do have one can run safely at two ohms.
cardmaster91
i don't need to know how to remove door panels, thats pretty easy to do. i want to get to the wires where they enter the body of the car.
96cherry
livonia
remove the door handle trim, there are 2 screws i belive in the handle the rest of the panel are push pins, an easier way of running a four channel is what i did, i took all the speaker wire running from the four channel and ran it to the back of the radio and tied them in to the speaker wires quick, simple, no headaches
bsamoul
The Bay, CA
Under the driver's seat is the amp, just take the wires from that, way easier and don't have to take the door panels off.
