Removing door panels
hunterxx12
Hello - I need to pull my passenger side door panel to replace my side mirror. Anyone have any recommendations, tips or step by step instructions.
Thanks in advance.
If all you plan to do is replace the mirror, then all you have to do is remove the triangular trim in the upper front corner of the door panel. It's clipped in place, so all you have to do is pull it out. This will give you access to the nuts holding the mirror in place.
hunterxx12
jkmotorsports - thanks for the response. I had no problem unbolting the mirror - that seemed to be the easy part. Getting to the wire connection behind the door panel for the power/heated mirror is where I am looking for guidance.
