dearoledad
- Dec 30, 2008
The range on the remote starter is ridiculously short. If I can't see the truck, it won't start. I am used to an aftermarket remote on my prior Tahoe. It would start from inside just about any eatery or office building. When it is 105 outside, you need a lot or time to cool things down and the "line of sight" thing means I can walk to the truck in about 45 seconds and that doesn't cut it. The old starter worked to about ¼ mile. When you are inside of an office building you need that kind of power just to reach 500 feet into the parking garage. Is there an aftermarket replacement key fob that has more reach than the OEM unit?
I don't care for the HVAC requirement to have the AUTO setting turned on. If I know it will be iced over in the morning and decide to set it on defrost instead of auto, there is no reason the heat shouldn't blow onto the windshield. But, some genius designer felt the truck knows better than the driver and instead heats the floor when the AUTO setting is on. I do, however, very much appreciate the seat warmers coming on.
