Rear shock removal help!!!!
HitandRunDriver
So Cal
I'm in the middle of taking off the rear shock, but on the top bolt, only one side is visible, the other bolt is tucked away behind the frame and i cant even see what i'm doing back there. Should i take off the spare to get some clearance or what??
Big Tap
Austin, TX
I've never done it before, but removing the spare seems like a simple thing to do to get some needed space.
HitandRunDriver
So Cal
Yep, dropped the rear tire and got tons more room, first shocks replaced, onto the next one
pincusa
NY
I did it without dropping the spare. Just put an extension on the socket, and you'll be OK. The fuel stuff is a little in the way, but it's not a bad job still.
