wondering if anyone has had the same problem. right when the truck stops it feels like the rear axle moves. when you let off the brakes to start moving you feel it move again. looked at ujionts and u bolts looks fine.can anyone help
I'm going to guess you are feeling the drive shaft sticking and then releasing on the spline, where it goes into the rear of the transfer case.
When you come to a stop, the banjo housing wraps up slightly moving the drive shaft. It is held in place with the brakes. As soon as you release the brakes, the spline can slide back to the cruise position.
If it is sticking, it will make a soft clunking noise and you of course can feel it too. It may not do it each time you stop. Easy fix, just pull the drive shaft off and put a little grease on the spline.
you mean where it come out the back of the Tranny? And where is this "Spline" Is that on the Front or the Rear of the Driveshaft... and do i just pack it down with grease? cause it's driveing me "balls up the wall".
Is their a anything to look for when taking apart the Ujoints, you said to make sure their in good cond.? what do you look for in those?? also what makes the driveshaft do that? was their never grease in their the first place or what??? Should we worry about filling the tranny with some more fluid since i leaked a bit???
Do i need to do the same to the front driveshaft?
