rear ac
jnoda757
hello, has anyone had a problem with their rear ac not working, if so please tell me what the fix was if you will, thanks
CJR2
Southwest Ohio
I am having the same issue with my 02 LT. I have checked all the fuses and they are good. If I leave the fan control on it will start blowing as we drive around. It doesn't seem to be switch related.
It could be a loose wire but I am wondering if it could be blower motor. I had an old drill that had a bad spot on the armature. If you manually rotated the chuck the motor would come back on. Does anyone know where the rear blower motor is on a Tahoe?
Thanks!
CJR2
Southwest Ohio
Please Help!!
I was hoping someone could knowledgeable Tahoe aficionado could give some good advise on this subject?!?:ack:
