Rear ac problem on 2007 Tahoe..
Zhoward6702
The front ac blows cold just fIne. The rear is only blowing hot. Any ideas what's wrong and about how much to fix? Any help is appreciated.
Welcome to the neighborhood!
There may be something wrong with the control pannel that controls the rear heat/ac. I'm not real sure how much it would cost to fix but I can find out in the morning.
Nerk
Not sure if it's the same thing, but I had a problem in my '08 where the passenger side AC blew hot air while driver's side blew cold air (and the exact opposite in the winter) and the dealer replaced an "actuator" and that solved the problem. Cost me just under $300.
Nerk, your issue was more than likely the blend door actuator, another common issue. His could be an actuator not functioning, but for the rear I have seen more of the contro panels go bad.
