Radio Wiring
dye4metal
Sarasota, Fl
Alright so i have an 02 LS without bose and onstar, standard. So i bought a jensen flip out head unit online and so i go to install it and i have already swapped all the door speakers with alpines and so i got the wiring harness and install kit from crutchfield and so the unit came and i wired up everything acorrding to the diagram. It all came on but no sound? I was at my mechanic the other day having a tune up and he even said he doesnt know what is wrong, we suspected the harness is wrong but crutchfield says it isnt but the head unit puts out b.c i can wire a speaker straight off the units harness and it will work. idk what to do and sound advice wants $200 to install anything with a screen. :eek:
Make sure the blue wire on the adapter is connected to the blue or blue/white wire from the deck. Even though it isn't the Bose Premium system, it still uses a standard factory amplifier.
dye4metal
Sarasota, Fl
i will try but even with out it i can still hook up a stock factory speaker to the harness off of it and it will play
It will play from the harness off the radio but not through the factory amp if the amp isn't powered up. The blue wire from the radio will power up the factory amp.
dye4metal
Sarasota, Fl
your a genius i let it sit in my garage for about 2 weeks, anyways i need the din cage to keep it in place. also the screen hits the lever when its in park : ( damnnnnn. ill just open it after i turn it on
dye4metal
Sarasota, Fl
yeaaa i just need to get a DIN cage to keep it from sliding around, they never sent it in either the kit or the unit. but i sware i hooked the wires up before but damn. thanx
