Calicajun
Changed out the radiator in my 2013 Tahoe from the stock one to a radiator that allowed me to installed the engine oil cooler lines. The new radiator is an all aluminum core with aluminum side tanks for the trans and oil cooler lines. I have also installed an external trans cooler (it work great).
The two problems I am having now are; the engine temp while driving only gets up to about 170 to 180. If the Tahoe is just sitting the temp will get to 210 degrees and stay there but soon after driving the temp drops. Even towing a 6,000lbs travel trailer for 700 miles the temp rarely made it to 210. The other problem that has started is once every few days the temp gauge stays at zero and a message shows up saying "engine hot A/C turned off". Then if I disconnect the battery for a couple of minutes everything resets and the gauge starts working again and the message goes away.
I had a new factory thermostat installed with the new radiator, so I'm at a lost as to what is going on the Tahoe. The only idea I can come up with is that the thermostat doesn't close all the way allowing water to flow all the time. Are thermostats suppose to stay open a little or close off completely? Anyone have any ideas or suggestions. Or the newly installed oil cooler lines going into the aluminum radiator side tank is cooling the engine oil too much cause a drop in engine temp?
Thanks,
Craig
Thanks,
Craig
