Document ID# 744008
2002 Chevrolet Tahoe - 4WD
DTC P0446
Description
A restricted or blocked evaporative emission (EVAP) vent path is detected by the control module monitoring the fuel tank pressure (FTP) during normal operation. The control module commands the EVAP vent valve OFF, or open, and the EVAP canister purge valve ON, or open. The fuel tank pressure should remain low as vacuum is drawn on the EVAP system. If the vent path is blocked or restricted, the vacuum level will increase and DTC P0446 will set.
Conditions for Running the DTC
DTCs P0107, P0108, P0112, P0113, P0116, P0117, P0118, P0125, P0440, P0442, P0443, P0449, P0452, P0453, P1111, P1112, P1114, P1115, P1120, P1220, or P1221 are not set.
The ignition voltage is between 10-18 volts.
The barometric pressure (BARO) is more than 75 kPa.
The fuel level is between 15-85 percent.
The engine coolant temperature (ECT) is between 4-30°C (39-86°F).
The intake air temperature (IAT) is between 4-30°C (39-86°F).
The start up ECT and IAT are within 9°C (16°F).
The vehicle speed sensor (VSS) is less than 121 km/h (75 mph).
Conditions for Setting the DTC
The fuel tank pressure is less than -10 inches H2O.
The condition is present for as long as 30 seconds.
Action Taken When the DTC Sets
The control module illuminates the malfunction indicator lamp (MIL) on the second consecutive ignition cycle that the diagnostic runs and fails.
The control module records the operating conditions at the time the diagnostic fails. The first time the diagnostic fails, the control module stores this information in the Failure Records. If the diagnostic reports a failure on the second consecutive ignition cycle, the control module records the operating conditions at the time of the failure. The control module writes the operating conditions to the Freeze Frame and updates the Failure Records.
Conditions for Clearing the MIL/DTC
• The control module turns OFF the malfunction indicator lamp (MIL) after 3 consecutive ignition cycles that the diagnostic runs and does not fail.
• A current DTC, Last Test Failed, clears when the diagnostic runs and passes.
• A history DTC clears after 40 consecutive warm-up cycles, if no failures are reported by this or any other emission related diagnostic.
• Clear the MIL and the DTC with a scan tool.
Diagnostic Aids
An intermittent Condition could be caused by a damaged EVAP vent housing, a temporary blockage at the EVAP vent valve inlet, or a pinched vent hose. A blockage in the vent system will also cause a poor fuel fill problem.
Test Description
The number below refers to the step number on the diagnostic table.
This test determines if the failure is present or intermittent.
Step
Action
Values
Yes
No
Schematic Reference: Evaporative Emissions (EVAP) Hose Routing Diagram
Did you perform the Diagnostic System Check-Engine Controls?
Go to Step 2
Go to Diagnostic System Check - Engine Controls
Did DTCs P0443, P0449, P0452, or P0453 set?
Go to Diagnostic Trouble Code (DTC) List
Go to Step 3
Inspect the EVAP system for the following conditions:
A damaged EVAP vent valve
A pinched EVAP vent hose
Did you find and correct the condition?
Go to Step 14
Go to Step 4
4
With a scan tool, review and record the Freeze Frame/Failure Records.
With a scan tool, clear the DTC codes.
Perform the Service Bay Test. Refer to Service Bay Test .
Does the scan tool indicate that the Service Bay Test has passed?
Go to Diagnostic Aids
Go to Step 5
5
Disconnect the purge line from the EVAP purge valve.
Turn ON the ignition, with the engine OFF.
With a scan tool, observe the FTP parameter.
Does the scan tool indicate FTP near the specified value?
0 in H2O
Go to Step 6
Go to Step 8
6
Turn OFF the ignition.
Reconnect all previously disconnected hardware.
Install the J 41413 EVAP Pressure/Purge Diagnostic station and the J 41415 Fuel Tank Cap Adaptor.
With a scan tool, seal the EVAP system.
With the J 41413 , pressurize the EVAP system to the first specified value.
Disconnect the EVAP vent hose from the EVAP vent valve.
Does the scan tool indicate FTP near the second specified value?
5 in H2O
0 in H2O
Go to Step 10
Go to Step 7
7
Disconnect the EVAP vapor pipe from the EVAP canister.
0 in H2O
Go to Step 13
Go to Step 11
8
With a scan tool, observe the FTP sensor voltage.
Is the FTP sensor voltage more than the specified value?
4.3 V
Go to DTC P0453
Go to Step 9
9
Test for poor connections at the harness connector of the FTP sensor. Refer to Testing for Intermittent and Poor Connections and Connector Repairs in Wiring Systems.
Go to Step 14
Go to Step 12
10
Replace the EVAP vent valve. Refer to Evaporative Emission (EVAP) Canister Vent Valve Replacement .
Did you complete the replacement?
Go to Step 14
11
Replace the EVAP canister. Refer to Evaporative Emission (EVAP) Canister Replacement .
Go to Step 14
12
Replace the FTP sensor. Refer to Fuel Tank Pressure Sensor Replacement .
Go to Step 14
13
Repair for a blockage in the EVAP vent hose.
Did you complete the repair?
Go to Step 14
14
Reconnect all of the EVAP hardware that was previously disconnected.
Go to Step 15
Go to Step 3
15
Use a scan tool in order to observe the stored information, Capture Info.
Does the scan tool display any DTCs that you have not diagnosed?
System OK
Document ID# 744008
