Power Door Lock problem
Harbison
Bought a 1998 2 Door Tahoe. Doors lock automatically when put in gear and unlock when turned off but neither door button works. Any ideas where to start? Doesn't have a key fob. Thanks for your help
Probably bad door lock switches, can ohm them out.... That being said, www.rockauto.com lmctruck.com are a couple good places to look...
Harbison
More info
All three switches are inoperable (back door) It would seem unlikely that all three were bad. Is there a fuse or relay that operates these?
MO Viet Vet
Soon to be Missouri
You just bought it you said. Do you know if they all stopped at one time over individually over a longer time? We can assume if you want.
Harbison
Good question, to which I do not have an answer. I have figured out another clue: the lumbar supports do not work. according to other posts the lumbar support and lock relay are tied into the cigarette lighter and accessory fuses. So I will check that out after work
