joeysworld
- Sep 6, 2008
1999 Tahoe 4 door 4x4
The driver/passenger side power door locks are intermittently or not working at all. The drivers side PDL never responds when the switch is used, and the passenger occasinally works. The rear barn door does't work as well.
When I took the door panel off on the drivers side, and when I inituated the switch, I could see that there was a very slight response.
The 2 rear doors work fine when the switch is used and when I use the remote.
Is there a relay that may be causing this?
Any help appreciated.
