Power Cord
YukonJacks
PA
Does anyone know if I can remove the plug end of a GPS power cord and wire it directly, instead of plugging it into the cigerette lighter.
Most of the portable nav units run off 5V, with the transformer being in the plug. You'll have to use a socket adapter then hardwire it, or solder wires to the end of the plug and hardwire that way.
YukonJacks
PA
thanks JK, your a wealth of information. I tore one apart last night and I saw the circuit board/xfrmer. I have to tear out the dash to find out why my rear speakers and sub stopped playing 1st.
dye4metal
Sarasota, Fl
if it is 12 volts you can run a relay or even hard wire it with a fuse holder to the battery with simple ring terminals.
bigggbrutis
South Dakota
I was thinking about installing an after market cig socket in my center console.. what would be the requirments or where would I tie in the pos/neg for the cig socket? I thought about hooking directly into my power and neg blocks i have set up for my amps, any ideas?
