thoguhts from a shade tree...
OK, I see it locks to the VIN. Question answered: you have to reset it back to factory to use it on another vehicle.
Here's another stupid question:
Ever since this past summer, my 5.3 pings when using 87 octane. Tried doing tune-up, replaced plugs and wires. I just tried 87 again on this last tank, and it was pinging again this morning on quick acceleration.
I see that that the Hypertech can be configured for 87 octane. Anyone know if this will solve my pinging issue?
Search "Sea Foam" on here. Follow the directions on the can. The pinging, if worsening, or, new, can be caused by carbon build up. The carbon build up in the chamber creates an eventual "hot spot". This hot spot can cause unwanted combustion in the chamber (pining). It can also be caused by bad timing, bad knock sensors, etc..however, I would doubt you are having major mechanical issues. Does it ping after the motor warms up? Does it ping when it is cold? I do know that these motors have a history of light detonation from the manufacture. GM considers most of this "normal" if it is light and does not worsen. If yours has just started, or has a heavy sound to it, try the Sea Foam (It's cheap, do it any way, it is worth it)
The Hypertech might sort your truck out as well (remember, I said might). I run the premium fuel tune on 87 octane with out any knock...but it is cold out. This summer, I might have to step up to mid grade or premium.
Lets remember about fuel grades; 87 octane is low in detergent(s). Premium is higher in detergents and will maintain a cleaner combustion chamber over the same mileage as a vehicle that was run with 87. If you drive like me (grandpa) and the motor operates constantly at low low RPM, it will build carbon deposits faster.
Run the Sea Foam, Get the Hypertech (or comparable hand held tune in a box, custom tune, etc), and give your truck the old Italian tune up on the occasion to help keep it cleared out
About the higher air flow/more fuel: From what I have been taught, read, etc; Yes, it does cause you to dump more fuel. My GTO suffered with a drop in K&N. I staggered my frequent 7 hour trips with the paper air filter and the K&N (lightly oiled and well cared for). The K&N did worse on MPG every time. The car even felt slower. I put on mufflers, it got better. However, there is a bit of a quirk over in the GTO world where folks aren't getting big gains from CIA's. But that is a different vehicle all together. However, your theory is right. More air in, more fuel added to make up for it....to a point. It is not quite like a carb.
Given a carb adjusted for a certain air and exhaust restriction; you take off the air restriction you foul the plugs with a overly rich mixture. If you put on long tube headers (removing exhaust restriction), you foul the plugs and burn the valves (over time) running a lean mixture. However, if you adjust the carb for the proper fuel demand (now higher with less restriction...i.e. motor needs more fuel to remain at peak efficiency) your power increases and the motor runs strong. Fuel Injection is the same...but..
Our trucks have somewhat of a brain that will work against that kind of sway in the overall performance/tune of the engine. It is built to be able to operate under different atmospheres, different fuel grades, etc (think sea level, to rocky mountains) and adjust accordingly. If you tune your engine (like setting the fuel mixture, etc) you will realize your gains
more over, than just putting on the CIA and letting your stock ECU do the work. That said, yes, CIA's help, mufflers/exhaust are a good pairing, and a tune really brings it all together by telling your ECU, "Hey, here is what you do with this new found freedom). With those factors, you have made your motor most the efficient it can be, you'll demand more fuel, make more power, and technically, get better MPG's at a
sane speeds now that your power plant is working less to move your rig.
