PCM HELP?
This weekend I finally did the electric fan conversion on my 03 Tahoe. The fan assembly is from a 05 escalade I was told, the headlight wire harness I got myself off a 05 z71 from a junkyard with the pcm as well. While I was collecting the needed parts I also got a new water pump and a 160 thermostat to help cool better. So me and my two buddies started Sunday noon and finished 10 pm. My engine bay looks great now with the e-fans. Problem is the pcm from the z71 is not working with my truck, I was hoping to avoid going to the dealer to program my pcm by using this pcm from the z71 since this one had the elec fans. The truck just cranks but it won’t start, I tried the security relearn process but no luck, I cranked for a few seconds to attempt starting it then left the ignition on for 11 min then repeated this step two more times but still no luck so I put my pcm on and the truck starts fine but fans won’t come on not even with the ac, by the way I had the fans turn on manually. Both pcm's have the same colors on c1 blue and c2 green. My pcm harness is c1 blue and c2 green. The fan wires from the headlight assembly which I got from the z71 that go to the pcm are green and blue. On my harness both c1-42 (blue connector) and c2-33 (green connector) were empty so I put the pins in there and soldered them with the harness. Now if anyone has any suggestions solutions for me as how to get that z71 pcm run with my truck please run it by me I’m all ears, lol. :confused2: Any input is greatly appreciated
