Options with VIN
rirusstah
Is there a place in the web where the list of original options (or something like the "bill sheet") are listed if you input the VIN number?
Tahoe Z71 2005.
Thank you
Sinjin
I've seen some but not very good in my opinion. To get your options you'll need the RPO codes off of the label in the clove box. The best place I know of to get accurate information is in the shop manual. HELM makes the shop manuals for most domestic vehicles. You can find them at www.helminc.com
rirusstah
Thank you for the information.
I found this list or GM RPOs but I'm missing some codes that are not on this list
http://www.marshu.com/images-website/car/gm-firebird-camaro-rpo-car-door-manufacturer-codes
Some of the missing codes are:
AXP
PDC
R9U
VSX
1SL
1SX
6XL
7XL
921
922
Any ideas where to find these?
Thank you again.
I was also looking for the Transmission Model #- Transfer Case Model # . Rear Differential Specs. , Spark Plugs and any info of Truck. as reference for Oils and such.
The Truck Model is CK15706 - 116.0
rirusstah
I found this which is pretty handy.
RECOMMENDED FLUIDS AND LUBRICANTS
Engine Oil - API "Certified For Gasoline Engines"
Viscosity - 5W-30 Recommended, 10W-30 Okay if 5W-30 Unavail.
Fuel - Unleaded Gasoline - 87 Octance Minimum
Automatic Transmission Fluid - DEXRON III Automatic Transmission Fluid
Automatic Transfer Case
New Venture 236 NP8, New Venture 246-NP8 - GM Auto Trak II Transfer Case Fluid
Borg Warner 4481-NR3, Borg Warner 4482-NR4,
New Venture 149-NP, New Venture 149-NP3,
New Venture 263-NP1, New Venture 261-NP2 - DEXRON III Automatic Transmission Fluid
Differential
Front
Selectable 4WD - SAE 80W-90 Gl-5 Gear Oil
Full Time 4WD - SAE 75W-90 Synthetic Gear Oil
Rear
Quadrasteer Rear Axle - GM Synthetic Axle Lubricant
Power Steering Fluid - GM Power Steering Fluid
Brake Hydraulic Fluid - DOT 3 Brake Fluid
Engine Coolant - 50/50 Mix of DEX-COOL Coolant and Demineralized Water
Parking Brake Mechanism Grease - White Lithium-Based Grease NLGI no.2
Chassis Lubrication Grease - NLGI Grade 2 or GC-LB Chassis Grease
Hood, Door, Trunk Hinge Lubricant - Lubriplate, lubricant aerosol spray
Door Hinge and Check Spring Grease - NLGI no.2 Multi-Purpose or Equivalent
Key Lock Cylinder Lubricant - Graphite Spray
Hood Latch Assembly Lubricant - NLGI no.2 Multi-Purpose or Equivalent
Door Latch Lubricant - NLGI no.2 Multi-Purpose or Equivalent
CAPACITIES
Engine Oil (inlcuding filter)
V8 - 6.0 Quarts
Manual Transmission
New Venture 3500 - 2.2 Quarts
New Venture 4500 - 4.0 Quarts
ZF S6-650 - 6.3 Quarts
Fluid and Filter Change
4L60-E/4L65-E - 5.0 Quarts
4L80-E/4L85-E - 7.7 Quarts
From Dry, Including Torque Converter
4L60-E/4L65-E - 11.2 Quarts
4L80-E/4L85-E - 13.5 Quarts
Transfer Case
New Venture 246-NP8
1999-2001 - 2.4 Quarts
2002 & Later - 2.0 Quarts
New Venture 149-NP - 2.0 Quarts
New Venture 263-NP1 - 2.4 Quarts
New Venture 149-NP3 - 2.0 Quarts
New Venture 261-NP2
1999-2001 - 2.3 Quarts
Borg Warner 4481-NR3 - 1.5 Quarts
Borg Warner 4482-NR4 - 1.5 Quarts
Cooling System
V8 Engine
4.8L and 5.3L - 16.7 Quarts
6.0L
Yukon Denali, Yukon XL Denali - 19.0 Quarts
All Others - 16.8 Quarts
BRAKES
Disc Brake Pad Wear Limit - 3/32 Inch
Drum Brake Shoe Wear Limit - 1/16 Inch
Parking Brake Shoe Wear Limit - 1/16 Inch
IGNITION SYSTEM
Spark Plug Type
1999
V6 - AC Delco 41-932 or Equivalent
V8 - AC Delco 41-952 or Equivalent
2000
2001
V8 - NGK PZTR-5A15 or Equivalent
2002
2003
V8 - AC Delco 41-974 or Equivalent
2004 & Later
V8 - AC Delco 41-985 or Equivalent
Spark Plug Gap
V6 Engine - 0.060 Inch
V8 Engine
1999-2003 - 0.060 Inch
2004 & Later - 0.040 Inch
Firing Order
V6 Engine - 1-6-5-4-3-2
V8 Engine - 1-8-7-2-6-5-4-3
GMTech48
Chalfont, PA
Tahoe Z71 2005.
Thank you
send me the last 8 of your vin & I'll give you your build sheet
