Opinion on 2001 Yukon XL
thesheriff
Hello everyone, I am a newbie to this forum. I am in the process of possibly purchasing my first GMC. It is a 2001 XL SLT package. It currently has 71,000 mi on it and was owned by an older couple. It is looking like I am going to pick it up for the $10K mark. What is your opinions on this particular year and model? Anything I need to look out for or take care after purchase? Should I spend the extra money to get a factory backed 30K mi warranty? Finally, I was checking out the Hypertech 32000 max energy programmer and wanted to know if it was worth the money? Thanks everyone for you help!
JennaBear
CA
10K aint bad at all. I would change the fuel filter and run a top end clean. Also grease all the zerks and change the oil to synthetic (if not already changed). Check spark plugs and and air filters.
I wouldnt waste my money on a programmer nor the factory warranty, but to every man their own.
thesheriff
Sorry about the ignorance here but what is a top end clean? Also, were is the fuel filter located? Thanks
JennaBear
CA
I believe the fuel filter (on an 01) is located on the driver's side along the inside of the frame rail.
For top end clean I use Seafoam in the brake booster. Not sure if there is a write up here but I am sure that Google would come up with a ton of hits on "Seafoam".
