One headlight not working
CC85
One headlight out. Changed to new bulb, still not working. Cleaned connector with alcohol (didn't have anything else at hand) but nothing new. Any advice on what else this could be? Fuse or relay solution? What else do I try? Thanks!
Slammed
CT
yeah try the fuses ive seen this happen before (i never new they had separate fuses)
CC85
update
fuse for this lamp checked and swapped out a spare, both times didn't work. swapped relays for high and low beams, and the issue persists. i'm unhooking the battery as one more check to see if this would make a difference. seems now possibly wiring somewhere? still open to suggestions. will take to a shop soon.
Slammed
CT
Check for power at the pigtails I've had to change mine
