Oil pan gasket replacement.
caiden07
I was trying to replace the oil pan gasket on 07 Chevey Tahoe 2WD I got everything out except the oil pan won't come out because I can't clear the oil pump tube, I been trying it out for an hour and doing it gently that I don't wanna mess up the oil sensor. Is there any angle or proper way to clear the oil pump tube? Do I have to remove the power steering assembly for better clearance? Thanks.
Caiden
