Oil Fill neck loose
the_gambler
I just went out to put about a half a quart in my 05 Z71 5.3 ltr. The neck where you fill the oil is a little loose and can be moved a little back and forth. Has anyone had this happen? If so, can you just replace the neck or the entire valve cover? Also, is it anything to worry about? I'm afraid oil will start squirting out.
