Off the Streets
MURDEREDoutTAHOE
Hey all. Im looking to go from big rims and low pros, to little rims and some swampers. Just wondering if anyone knows off hand what the biggest tire that can fit under a Z71 on a 15/16inch rim is? thanks
z71offroader
17" rim is the smallest you can run because of the brakes. on stock suspension a 285/70/17 is probably the biggest and depends on ur rim, with a leveling kit you will gain more clearance from some bigger meats.
Rafael
I have 18" on my Z71. Any larger and I'd think I'd need to lift it to compensate for any bumps I would hit.
High4
You can use a 2" leveling kit and go with 33" tires with no rubbing.
