no spark no fuel
2hoes
So bought a 95 Tahoe LT the other day needs a head gasket and that's fine and dandy simple enough but got it home put it in the shop and come to find out theres no spark replaced the coil and ICM thinking maybe it would be that but no luck. Turns over fine and dandy. Did some tests can't remember exactly what at this point. But long story short no spark and no fuel spraying out The injectors turn the key and can hear the fule pump kick on took off the file line and its getting fuel....took a test light hooked it the the POSITIVE terminal and touched the purple wire coming off the ICM and sounds like the injectors are clicking but now I'm at a loss if it was a pressure issue I would think id have spark so any input at this point would be appreciated THANKS
2hoes
Btw have the distributer with The plugs coming all out the top
You have a TBI engine. Check for power to the ICM and COIL, if the pickup coil in the distributor is bad it wont fire either, same as if the ICM is bad, pull the ICM and have it checked at the parts store. Pickup coil can be ohmed out.
2hoes
I replaced the coil, pick up coil, cap,rotor and the ICM and still have no spark or pulse.....pump still kicks on and I manually tried to get the check engine codes and all it flashes I a code 12 when it dose tho on the last flash I hear clicking up front
2hoes
Now I got spark and it will start with starter fluid but file injectors won't push fuel its getting fule all the way to injectors cleaned them out and still nothing fuel injectors pulse checked with light
Check your fuel pressure, takes a certain amount of pressure to open the injectors. May have a bad/ weak pump...
