No brake lights?!
970tahoe
I have a '99 Tahoe LT, and when I turn the headlights on, I get the running "glow", but when I hit the blinkers, the emergency flashers, or the brakes nothing lights up. I have no flashers or brake lights!...WTF?! Is it as simple as a fuse, or is it a "dealer installed rape me in price" relay?
970tahoe
Also, I just recently installed 55W fog lights...don't know if that could **** with the circuit...
sasquatch094
ohio
there is a black connection box in the back under your hoe that has the taillight wires that go to it (its kinda like a 3 way plug, and depending if you have a towing package or not) and some times they get corroded and it stops the connections from happening.
GMCYukalade
NC
also - the brake light switch under the brake pedal - and also - there is fuses in both fuse boxes.. - or.. u have burnt out all the bulbs
96ProCompTahoe
Indiana
i have to go with the trailer connector. sometime i don't have rear tail lights with the headlights on. luckily my brake lights have worked thus far.
pull the plugs apart and clean them up.
