Newb with questions
Bulletbob5
Hello, new owned of a 1999 2door tahoe. Has 138000 miles, 6 inch super lift, 35" toyos, few other things. A couple of potential issues to address first.
1. Auto Transmission whines from cold start to about 5 mins. All but goes away after warmed up. Feels like a fluid issue. Fluid looks goods and full or a little over full. Is this an issue or normal? Any help is appreciated.
2. Blower only works on high and not always. Started once when I kinda turned it to high with pressure. Feels like a switch issue. Common?
Thanks in advance.
1, drian fluid, refill with proper fluid and to correct level, NOT OVER.
2. Could be the switch, could be the resistor, would want to check it out with a meter....
Bulletbob5
Thanks. Changing fluid this weekend. Confirmed that the switch is bad. Tap on it and it comes on or off.
get the filter changed out also....
Switches are notorious, sometimes the harness melts also.....
