98BleTahoe
- Sep 27, 2012
Hi there. We just got a new to us 1998 Tahoe with 70,000 miles on the clock. I have changed the oil and filter, filled the tires which are 2 yrs old to 35 PSI, and replaced all of the speakers except the front door tweeters just forward of the Window Switches. (Wow what a difference). Unfortunately I have noticed a whining noise especiallly from outside the vehicle, but can also hear it from the inside, and after reading through many of these threads, I may be hearing the fuel pump. So far the truck starts and runs just fine. I will soon be adding a 7 pin connector for our travel trailer at the rear bumper as well as a brake controller below the front dash next to the driver, as well as an auxilliary transmission fluid cooler in front of the radiator. I read some of the postings that indicated that the Fuel pumps whined for a year before they quit. Although I'm handy with tools, my garage is small, and I may have to take the hoe to the shop for the fuel pump replacement. With regard to connecting the Brake controller, up under the hood in the fuse box, there are two posts on the aft side toward the driver that seemed to be recommended by the manufacturer of the brake controller that I have ordered. I noticed that they are serviced by two 30 Amp fuses in front. I am wondering if it is possible to replace one of the 30 Amp fuses with an autoresetting circuit braker to feed the power to the brake controller as I would prefer that to the fuse so that I would not blow a fuse and then have no brakes on the trailer. With regard to the transmission cooler, does any one know which direction the transmission fluid flows from out of the transmission and into the radiator? Thanks in advance for any and all advice.
