As you can see from the dyno table, the best bang for the buck for the intake is simply to put in a K&N filter. There's really nothing wrong with the stock intake. It pulls cold air from the fender well. You can open it up a bit inside the air box. Replace the corrugated rubber connectors with straight rubber tube cut to the right length. Then you've got everything a high-buck cold-air intake has, for a lot less money.
For exhaust, unless you just like the "Flowmaster sound" (YUCK! :ack: Sounds tinny and rattly to me. And loud inside the vehicle.), consider a simple Thrush glaspack. They used to be Walker "Blue Swinger" until Walker became DynoMax and bought Thrush. The only glaspack with no restrictions, and the core is the same diameter as the inlet/outlet. Absolutely dead quite INSIDE the vehicle, and that classic, throaty rumble out the tailpipe.
After that, all you might need do mechanically is a set of headers.
Then get a tune. I'm wondering myself what the best one is. Not afraid to tune it myself if the price is right.
