SS5800
- Oct 2, 2007
I love this denali!
I love this denali!
894 is the bulb you need for an HID kit. But IMO, you need new housings. Their should never be moisture on the inside of the lens. Thier toast.
Talked to my parts guy, he says the fogs are going to run me 60 per side. Good price? Bad price?
no, that vid is a GMT400, so its the same truck. I've seen plenty of GMT400s with duals and super 44's. its a common setup down here in florida.
Great price. They are about 85-90 a piece on the web. Easy to change out also.
for that specific setup you would have to probably go to an exhaust shop. however, here's a link to the 50 series I'm gonna get. http://www.flowmastermufflers.com/products/index.php?main_page=product_info&products_id=3741
the setup you want wouldn't bolt up directly. since there's not factory dual exhaust, all the hangers on the left side exhaust have to be welded up.
You wouldn't happen to have a link for that catback would you? Or would I have to buy the Super 44 and big tips, take it to an exhaust shop and have them fab up the rest?
Alright then I will order them tomorrow. And as for my headlight housings... I thought they had condensation in them, but actually just the turn signal housing has the condensation and those are $35 per side. And since I have a grill guard, I will likely need to remove it to install the HID kit. Right?
That seems kind of steep, doesn't it? I mean it's probably an $80 muffler... so does that mean the madrel bent pipe is worth $330?? I really would like to have dual out the sides but I don't want to spend an a$$ load on that because I have lots of other ideas for the truck. Would I notice that big of a difference with that catback versus me just buying a flowmaster muffler and slapping it on my stock pipes?
You can keep the grill guard with an HID kit. Infact it looks cooler. everything to do with the HIDs goes behind the headlight housing.
oh, trust me, my plan wasnt to buy from flowmaster directly. if you piece it all together and have a shop do it, it will be cheaper.
So you don't think I would have to take the grill guard off to do the install(I intend on putting the grill guard back on, but to DO the install itself, if that's what you were thinking)?
As long as you can open the hood. I dont see why you would need to. Enless your changing the headlight housings (not the fog ones, those are seperate) then yes you will most likly need to. But to just put an HID kit in and change your fog light housings, Naw. Have plenty of room.
