scotto2323
Need help with diagnosising my DL3 problem. All parts were bought used. I recieved my DL3 mirrors first, removed the covers and tested both powerfolding motors. Both motors worked fine, so I installed the mirrors.
After install, the mirrors: adjusted, signaled, and heated.
Just installed the DS window switch and here is whats going on. (all windows and door lock function work)
Driver side works fine: power folds, adjusts, signals, dims, puddle lamp, and heats. The option for reverse tilting is now in the DIC and this functions correctly.
Passenger side: The only things that work are the adjustments, signal, and heat.
Why is the passenger side the only side not working? Do I still need to get the tech2 programming? Keep in mind the only problem I see are the non working puddle lamp and passenger side fold.
