I'm looking at some 17 inch rims with a 7.5 width. I want to put 33's or even 35's on them but not sure if they'll fit. Also going to be putting a 4-6 inch lift. Any help is appreciated, thanks!
Putting them on my 96 Tahoe. They make a size 34 tire as well, hope those fit the rim. Called discount tire and they said they should but would have to bring them in to see. Thanks!
35's will clear with a 4-6" lift. May require trimming inner fender a little. As far as the 33's on 7.5 will clear fine. If you go with a 10" wide rim then you may would run into same problem as with the 35's. The other option is to go with the 7.5" width and run 35's put a spacer between rim and hub.
