all-power
My name is Will first time posting, I hoping you guys can point me in the right direction with my problem!
I have a 97 Tahoe LT 4X4 and I have a oil leak I found it when i was changing my pitman arm not sure where its coming from! The leak is in the front of the truck, I had a local shop look at the truck and they said that it seems to be coming from the front seal! I not sure where that is so I need to know if that something that can be change while the motor is in the truck? Has anyone had to replace the seal?
Thanks in advance for your help!!!
