Need help about transmission cooler
jmarkham1249
I. Recently hit a deer and it busted my transmission cooler along with a lot of other things. I need to know what the smaller cooling device is right next to it it's thin and tall on the right side. It's an 01 Tahoe and also where is the best place to get Oem parts to fix my front end. Like bumper bumper fillers headlight housing units ect. Please help I also I have broken part they looks like it came off the cooler and I can't find out where is came from ill have a pic if anyone can help thanks
rockenthebowtie
Any time I want
Its a radiator insulator guide its goes on the bottom of the raditor there should be 2 for the right and left side theres 2 nipples at the bottom of the radiator that the rubber insulators slide onto the insulators then slide into the holes of the body's frame
jmarkham1249
Thanks so can I replace that one part or what do I do the radiator housing frame is bent pretty bad on the driver side it's sitting sideways the radiator isn't leaking
rockenthebowtie
Any time I want
Well if you mean replace it as in putting it back once you get the body work done ? Yes... but if you mean as in getting another one ? nNo.. its not necessarily you can re-use that same one.. Although once the body work is done you do want to replace the radiator
jmarkham1249
I'm just asking do I need to replace the whole radiator because of that one part or can I just replace that part
jmarkham1249
I didn't have full coverage so I am doing this out of my own pocket and its pretty shallow I'm just trying to only replace what I have to
