Okay guys - here we go.
Vehicle: '01 Tahoe 4wd 5.3l 179,000 miles
Problem: Driving down the road, let off the gas to stop or make a turn, the engine dies. Sometimes starts right back up, sometimes won't start right back up. Sometimes if I let it sit it starts back up. Sometimes I can go for miles and miles and no problem. Today I didn't make it around the block.
Already done:
Replace Fuel filter first - no obvious issues there, same problem.
Checked fuel pressure - 52 lbs not running, 46 running.
Replaced Fuel Pressure Regulator - no obvious issues there, same problem.
Checked fuel pressure - 52 lbs. not running, 46 running.
Replaced Fuel Pump - no obvious issues there, same problem, if not worse.
Checked fuel pressure - 55 lbs not running, 48 running.
No CEL, no codes, no luck.
Any ideas? I am about to see what 40 lbs of Tannerite can do to a Chevy Tahoe!
Already done:
