MAF screen removal?
87gtNOS
Toronto
Hey guys, I had removed my stock screen on my Mustang and my PRO-M 77mm MAF never had a screen....so why not remove the screen from my Tahoe's MAF?
JennaBear
CA
It is not a good idea to do this on these vehicles. The screen evens out the airflow
and a smoother airflow across the MAF filaments in a turbulent tube provide a more consistent reading. So a removed screen will cause an airflow calculation discrepancy of up to 15% over stock.
Here is a visual:
87gtNOS
Toronto
Interesting...with my supercharged Mustang, I found that the meter had to be 'clocked' a certain way to achieve a good idle! Could this be simply the case once you remove the screen on the Tahoe?
Your charts are for idle or WOT?
JennaBear
CA
Those charts are at WOT. Really a stock MAF, with screen in place, is more than ample to prove 400+ hp, there really is no reason to remove it. As far as clocking it to a certain angle, you shouldn't have to, screen provides that ease of operation.
