lower radiator hose removal?
DVR4
Columbia, SC
Today I set off to change the spark plugs, thermostat, heater control valve, upper radiator hose and lower radiator hose. Everything went well until I got to the lower hose clamp on the radiator. The tabs on the friction clamp are pointed to the inner fender and I don't see any way to compress them. Seems like my options are removing the inner fender liner, removing the radiator, fabricating some type of compression tool out of a bolt or attacking the fender liner with tin snips or a hole saw. I'm sure someone else has dealt with this before so I'm hoping to get some suggestions. I have a new hose and conventional hose clamps to replace the originals. Any help would be appreciated. Oh and all the other tasks have been completed. TIA
I just had a right angle pair of slip jaw pliers.... Then I used a worm drive clamp in return with the new hoses and radiator.
DVR4
Columbia, SC
I dropped the passenger side inner fender liner and got it. My truck has 6" of lift. If not, the wheel would have needed to be removed too. I assume the radiator was installed with the lower hose attached. I don't think the hose was original. Those clamps were a major PITA.
Thanks for the reply
2000tahoez71
Those clamps are the devil. If you don't have the tool that makes them easy, they will give you gray hairs.
2000tahoez71
Those are awesome, never seen the flexible version. Let me know how they work!
They can be a major PITA, or they can be a godsend.....
