Low Coolant Warning
terrycounciljr
I am getting a low coolant warning, but the coolant is not low. I had my shop check for leaks when I got my oil changed and they did not find any leaks. The warning does not come on all the time, I would say probably every other day or every third day. Any one else had this problem? I am just thinking that the warning would not be coming on if there was not some sort of problem going on. Thanks for any help.
The sensor is in the overflow reservoir. Even if it does not look low, once it gets to a certain level, the sensor will trigger the warning light.
