Locating the cabin air filter in 01 YUKON
NCgatorguy
Charlotte,NC
I got a reply to this from a Hoe owner but think mine may be differant. My passanger side kick plate has no botls and is full of wiring. Anyone else out there replaced theirs in thier Yuk?
Thanks for the help to a NEWBIE here!
Did you look behind the kick panel or underneath the dash/glovebox area? The filters are to the left of the blower motor underneath the glovebox area. You have to remove three 7mm screws on the underdash panel. Once that is removed, the filter access panel has a screw that needs to be removed then you can gain access to the filters. This is only for 00-02 models.
NCgatorguy
Charlotte,NC
Thanks JK.......found it and also put the cheaper ($17.99) filters in from AutoZone. Picked up a Haynes manuel while i was there. $22 on Haynes website and $19 @ AutoZone! Going to tackel the door panel today and see if my motor is tuck or burnt out??? Autozone has one for $101 with regulator or a cheaper brand for $85. Any suggestions?
Thanks again
