License plate relocator box in tailgate
sasquatch094
ohio
Hey, i have a quick question.. has any one but a license plate relocator box in their tailgate?? i have a box i got from my buddy, but i was seeing if anyone put on in, as far as how hard it would be to cut out a square and weld that in.. has anyone done this?? thanks:ttiwwop:
96ProCompTahoe
Indiana
minus having to grind it down once its in the tailgate so it will follow the contour of the tialgate, its not hard. i took 2 years of autobody classes. if you can follow a straight line with a cut off saw, weld and can use a grinder your home free.
just make sure you have the proper clearance behind where you want to put it before you start cutting up your tail gate. :)
sasquatch094
ohio
yeah i think im going to doit to mine.. i jsut need a rollpan now..
sasquatch094
ohio
while im taking about frenching in stuff.. has anyone put on a bolt on or weld on roll pan on their hoe before?? if so how hard was it weld or bolt and how long did it... the bumpers already off, i think i jsut need to cut the frame?? and then some other stuff.. but it would only make sense to get the roll pan thats completely smooth bcuz of my box im putting in also..
