dirtyreds9
- Oct 17, 2011
Please help!!!!! 2000 Yukon xl, No barnyard doors
I purchased aftermarket LED taillights from X3 racing on EBay. When installed everything worked fine. Initially turn signals blinked rapidly, so had resisters put in and they work fine. For some reason ALL the lights work EXCEPT running lights at night or when switch is turned on. The turn signals, brake lights, and reverse lights all work.
Have replaced lights with new set from x3 racing with same outcome. Checked fuses and relays under steering column. Placed resisters on brake lights. When putting a bulb back in the brake light socket it works.
Is if the light? Truck? Or some other issue? Any ideas would help!! Thanks
