Okay...heres the instructions for programming the keyless entry remote:
1. Close all the vehicle doors.
2. Insert the ignition key into the ignition lock cylinder.
3. Press and hold the door unlock switch on the drivers door.
4. While holding the door lock switch in the unlock position, cycle the ignition ON and OFF three times (not turn the truck on and off three times, just cycle to where all the accessories come on).
5. Release the door unlock switch. The doors should lock and unlock to confirm the program mode.
6. Press and hold the LOCK button and the UNLOCK button at the same time on one FOB. If alls well, in approx 15 seconds, the doors will lock and unlock.
7. Repeat the previous steps to program up to four FOBs.
8. Turn the igntion switch to the RUN position in order to exit the keyless entry programming mode.
9. Check each FOB to confirm operation.
1. Locate the Data Link Port. It is located under dash drivers side. Be sure you know which pins are 8 and 4.
(Notice port is wider on top row)
2. Make sure there are metal contact pins in terminals 8 and 4. Connect 8 to 4 with a suitable jumper wire (leave the jumper wire connected throughout the programming procedure). Make sure you know which terminals are 8 and 4. The vehicle will respond by locking and unlocking the doors to signify entering of programming mode.
3. Press and hold both the LOCK and UNLOCK buttons together on the first transmitter to be programmed. After about 15 seconds, the vehicle will respond by locking and unlocking the doors. Release the buttons on the transmitter.
4. Within one minute, repeat the previous step on the remaining transmitters to be programmed.
5. Remove jumper wire applied to the OBDII Port.
Slammed, you are in the 07 + area. Do you have an 07 plus? It's hard to help when we are talking apples and oranges.
If you have an 07 + you can set the horn lights in the DIC.
How do you program the keyless remote?
