keyless entry on 97 Yukon
turner-2000tj
do all Yukons have keyless entry? I just picked up my Yukon up and the owner did not have a remote. I would figure all Yukons came equiped with this feature. Its an SLE if it matters...
Thanks
Mike97
Colfax, WA
I had the same question about a year ago. You can easily tell if it has keyless entry. Locate the OBD connector under the steering wheel column. Jump pins 4 and 8 together with a paperclip. If you have keyless, the door locks will cycle when the pins are jumpered. If the locks don't cycle, you don't have keyless.
Edit: I found the thread I started when I wondered the same thing. Go to post #8...
http://www.tahoeforum.com/showthread.php?t=1785
turner-2000tj
OK, got the remote from ebay and programmed it. Doors lock and unlock properly. Shouldnt the horn honk when I look it?
turner-2000tj
HMMM...Tested mine again this AM and when I press lock on the remote and I hear doors lock, I hit lock again and horn will honk. Also noticed that when I push unlock, it only unlocks drivers door. Push it again and it will unlock rear doors and passenger door.
Mine does exactly this but no horn...
clean95
sacramento
my 95 came with the gm keyless entry remote with a factory alarm with a siren.. at makes a chirp sound when u hit unlock and lock... weird and its all gm factory
