Hahaha naw... I didn't drive the truck hard.. but it was driven through a several snow storms, snow marshes, dirt trails, and sand dunes a few times... and towed my track car a few times back then. You're right about the silicone.. it might have been tightened a bit becuase it ripped along the hose clamp... but it also popped off a few times before too (which might have been why it was clamped down tighter). As for the box... it's only held on by 2 bolts and rubber bushings in between... and the air box is pretty heavy if you think about the way it is secured ( 2 bolts close together), and the rubber slowly fell apart (2-3 yrs?) and might have introduced some play on the bolts... which eventually over the yrs ended up shearing 1 bolt off. I'd call it wear an tear... but I still believe the overall design could have been better... however... I do love the monster filter it came with =)
As for the stock tube... it made the intake quieter than the K&N tube (I have stock exhaust too, so I'm not really after the noise on this truck)... plus now I have no problems whatsoever with anything popping off, etc... I just clean the filter when it gets dirty... that's it. Oh, and I did replace the 1 bolt and the air box is now secured.
**I also added a 1/4" thick foam rubber pad (available at OSH) to cover the bottom surface of the K&N cold air box. The filter is so big, it would rub up on the bolt heads that secure the box... so it's been padded now, and no more rubbing.
