rjohnson4405
- Oct 29, 2008
Attached are two pictures. The first is taken from the top of the engine, on the right side. The second is taken from the bottom of the engine also on the right side.
Is this the "weep" hole leak on the front of the water pump that indicates a bad water pump?
I've lost a gallon of coolant in the last week since I noticed the leak.
Should I still take it in to the dealer to have the system pressure tested?
Or can you definitively say that yes, this is a water pump issue?
Thanks,
Russ
Thanks,
Russ
