Interior Climate Control Fan - not stopping
MNYukon
I have 2006 Yukon SLT 5.3L.
Front interior climate control blower kept running even after engine off - key pulled
Pulled fuse to stop fan
Diagnosed it was control module under dash by fan
Truck has RPO of CJ2
Module has Part#: 52413530
On-line search (Amazon) shows 2 replacements via AC-Delco (1580567 and 1580568)
The "67" is $70 and the "68" is over $100
Any idea which is the correct replacement?
clkelley
Moderator
Galax, Virginia
Welcome to the neighborhood!
hmmm, no, I don't, I can find out, but it will be Monday before I can look it up and I will need you to send me a private message with your VIN#.
MNYukon
Thanks clkelly!
I ended up ordering the part #1580568 for just under $100.
Supposedly it is the replacement for the GM #93803634
We'll know in a few days...........
MNYukon
Not the right part!
Damn crappy cross reference lists
MNYukon
Try Again
I now ordered the item below - which no one has a photo but one on-line site has a "image" that looks like the correct shape and hole patterns.
I ordered: 1 A/C Power Module #(15-81728) (for GMC TRUCK YUKON) which is the number that superceded part # 15-80567
Who knew both 1580567 and 1580568 cross reference to the CJ2 RPO for my Yukon????????? PITA!!!
MNYukon
Second module came as kit - also not OEM. Kit contained new wiring harness. Module was right fit so decided to install. Had to cut and splice 3 wires. Took 10 minutes to install and put everything back in place.
Fan works!
Having trouble now getting on-line parts store to accept return part. Customer Service emailed back and said I should not trust their photo or cross reference - I should have used my VIN - another PITA
tonymac617
Boston, MA
Sorry you had such a hard time with your replacement part. Thank you for posting the part numbers and the correct one for your vehicle so that others will know the info. Hopefully, they will take your unused part back and issue a full return. Going forward, its a good idea to go to the Better Business Bureau website to find out info on any company that you wish to do business with before handing over your hard earned money.
www.bbb.org
