JK - think the Yukon was an exception? Ditto on the "easier" part - I don't know if it's even possible to get the trim off without lowering your column all the way down.
Maybe energ wasn't referring to his own...
I'm confused as to why you need to wire a BT adapter to speakers...
The harness on mine matched this diagram (second to last page):
http://www.installdr.com/InstallDocs/GM/PDF/460029.pdf
Try this - go to Wal-Mart and get the $8 aftermarket wiring harness (Scosche Brand) and tie into those wires. Then you don't have to splice anything on the stock harness while you're experimenting.
