How to fix window switch panel?
ac1975
Denver, CO
So while I had the camera out, I took a pic of the window switch panel. I was trying to see how to pop it off and fix it. But I didn't want to phug anything up. Any ideas? Looks like I just need to pop off the cover and snap the switch board back into that clip? How do I get the cover off?
oneradride
Omaha
There are 2 clips, if you have a panel popper, pry towards the center of the truck, directly away from the door panel.
ac1975
Denver, CO
Thanks for the tip. What if I don't have a panel popper? Long flat screwdriver? ... or do they sell those at an auto parts store?
Grebbler
Detroit,MI
Mine came up using hands alone. The door panel edge of the switch housing is the hinge tab area. The outer edge can be gripped and pulled up. The clips holding the housing to the door panel are along the door lock and mirror control areas (I had two).
The two switch boxes, mirror and window/lock, just snap into the housing.
Greb
oneradride
Omaha
Just about anything will work, if you are aggrieve enough you could probably do it with your bare hands. As the snap on dude says…. There is a tool for every job and a job for every tool….
If you do a lot of work on your truck yourself, you might think about getting something like this. They come in handy for a ton of things.
