HELP
bragado
Guys I need your help. I am changing the front axle shaft seal on my yukon denali 06. problem is I lost track wich way the seal goes. it's a GM OE seal.
does anybody done this one before?
clkelley
Moderator
Galax, Virginia
The way you are holding it in the third pic, the right hand side showing there goes toward the outside of the differential, the left hand side points inside the diff.
bragado
Thanks clkelley, that's what I was thinking but wanted to get a second opinion. thanks Again!
