help with strange jerking feeling?
kd448
Kentucky
Hello, just bought 01 yukon 4X4 with 100k and have started to notice a hard to explain "jerking" or "binding" noise when in reverse or drive and slowly turning the wheel to the left or right. You can actually feel it when it happens. I have not had the time yet to watch it from the outside of the vehicle when the problem happens. If anyone has heard of this type of problem I would love to get this problem fixed. By the way I love this forum.
Copper&BlackYukon
Mine does the same, as well as everyone else with 4x4. It happens when you have it in auto 4x4 and the front wheels tries to engage due to the extreme angle. I leave mine on 2 wheel hi unless the conditions make me throw it in auto. Change it to 2 wheel hi, and then make the same turn, you will see what I'm talking about.
kd448
Kentucky
Copper&BlackYukon, I've checked and It's not in 4wheel auto it's in 2 hi. That's what's got me so confused about this problem.
tybardy
i think it is you intermediate shaft... im pretty sure i am having the same problem only to a lesser degree... this is a common problem in these trucks and i recomend getting a beefier one to replace it w/
kd448
Kentucky
tybardy, Is there anyway I could check and tell if it is the intermediate shaft? I can't feel anything in the steering wheel when the problem happens.
kd448
Kentucky
It's hard to explain. I would say that I can feel it in my seat. It sorta feels like something is binding up. Could it be cv joints? I'm going to get the wife tomorrow to drive it up and down the drive way and see if I can see anything.
tybardy
man.. i definetly sounds like your 4wd is trying to kick in, what you are discribing sounds like exactly that.
other than that, i am at a loss... i dont think your cv joints would jolt around like that but than again i have never had a cv joint go out in a large vehicle like these. if you have ever heard a cv joint ever in your life i am pretty sure you would know it every time for the rest of your life, also easy to figure out, get under there and check to see if your cv boots are still packed with lube.
kd448
Kentucky
thanks, for your help, have you ever heard of one doing this? I guess the only way to see if it's in 4wheel is to jack it up and see. I've looked at the cv boot's and they looked ok.
tybardy
yea like i said, i have heard of this (my hoe did EXACTLY this) and it was the 4wd trying to kick in and out and in and out....
tybardy
well for me it was because i leftit in auto 4wd... now i leave it in 2wd and it never happened again... wish i could be morew help
kd448
Kentucky
Hello, just an update to this problem I'm still having. Still making the same jerking noise, maybe getting a little louder. Just found out whenever I put it in 4 wheel auto the sound is 50 times worse. I have been working alot lately and have not had much time to look under left front and try and figure out what this is. Does anyone have any idea's what it could be?
