P0356 ignition coil "F" primary/secondary circuit
i have switched coils and wire and it reads the same code, it has a misfire what else can i do to try and fix it. 2001 5.3L Tahoe LT, 108K, 4X4
Assuming you checked the third cylinder on the passenger side of the engine block, found the specs for resistance, measured the resistance from B positive to the coil and ground to B positive, and all were in spec, I would then turn towards the spark plug.
