help - hub assembly bolt torque specs.
welder
Hi,
I am brand new here.
I have a bad ABS wheel speed sensor.
I have been trying to find the torque specs for the 3 bolts that go through the steering knuckle and into the hub bearing assembly.
So far no luck finding it on my own .
Would you guys have a manual and check the torque # for me ?
Any help would be appreciated
Thanks
Tim in Ohio
welder
I found a site that had all torque spects listed
it is 133 foot pounds for the 3 hub bolts
and 129 foot pounds for the caliper bracket bolts.
In case someone finds this post and needs to replace the hub bearing or abs sensor.
I did it in just over 1 hour which included rotating my tires and it was very easy to do.
